In the C++ opennurbs SDK there several functions for evaluation of NURBS basis functions.
These two should do the trick.
Description:
Evaluate B-spline basis functions
Parameters:
order - [in]
order >= 1
d = degree = order - 1
knot - [in]
array of length 2*d.
Generally, knot[0] <= ... <= knot[d-1] < knot[d] <= ... <= knot[2*d-1].
These are the knots that are active for the span being evaluated.
t - [in]
Evaluation parameter.
Typically knot[d-1] <= t <= knot[d].
In general t may be outside the interval knot[d-1],knot[d]. This can happen
when some type of extrapolation is being used and is almost always a bad
idea in practical situations.
N - [out]
double array with capacity order*order.
The returned values are:
If "N" were declared as double N[order][order], then
k
N[d-k][i] = N (t) = value of i-th degree k basis function at t.
i
where 0 <= k <= d and k <= i <= d.
In particular, N[0], ..., N[d] - values of degree d basis functions.
The "lower left" triangle is not initialized.
Actually, the above is true when knot[d-1] <= t < knot[d]. Otherwise, the
value returned is the value of the polynomial that agrees with N_i^k on the
half open domain [ knot[d-1], knot[d] )
COMMENTS:
If a degree d NURBS has n control points, then the OpenNURBS knot vector
for the entire NURBS curve has length d+n-1. The knot[] paramter to this
function points to the 2*d knots active for the span being evaluated.
Most literature, including DeBoor and The NURBS Book,
duplicate the Opennurbs start and end knot values and have knot vectors
of length d+n+1. The extra two knot values are completely superfluous
when degree >= 1.
Assume C is a B-spline of degree d (order=d+1) with n control vertices
(n>=d+1) and knot[] is its knot vector. Then
C(t) = Sum( 0 <= i < n, N_{i}(t) * C_{i} )
where N_{i} are the degree d b-spline basis functions and C_{i} are the control
vertices. The knot[] array length d+n-1 and satisfies
knot[n-2] < knot[n-1] <= ... <= knot[n+d-2]
knot[i] < knot[d+i] for 0 <= i < n-1
knot[i] <= knot[i+1] for 0 <= i < n+d-2
The domain of C is [ knot[d-1], knot[n-1] ].
The support of N_{i} is [ knot[i-1], knot[i+d] ).
If d-1 <= k < n-1 and knot[k] <= t < knot[k+1], then
N_{i}(t) = 0 if i <= k-d
= 0 if i >= k+2
= B[i-k+d-1] if k-d+1 <= i <= k+1, where B[] is computed by the call
ON_EvaluateNurbsBasis( d+1, knot+k-d+1, t, B );
If 0 <= j < n-d, 0 <= m <= d, knot[j+d-1] <= t < knot[j+d], and B[] is
ON_EvaluateNurbsBasis( d+1, knot+j, t, B ),
then
N_{j+m}(t) = B[m].
ON_DECL
bool ON_EvaluateNurbsBasis(
int order,
const double* knot,
double t,
double* N
Description:
Calculate derivatives of B-spline basis functions.
INPUT:
order - [in]
order >= 1
knot - [in]
der_count - [in]
1 <= der_count < order
Number of derivatives.
Note all B-spline basis derivatives with der_coutn >= order are identically zero.
N - [in]
The input value of N[] should be the results of the call
ON_EvaluateNurbsBasis( order, knot, t, N );
N - [out]
d
N[d-k][i] = k-th derivative of N (t)
i
where 0 <= k <= d and 0 <= i <= d.
In particular,
N[order], ..., N[order_d] - values of first derivative.
ON_DECL
bool ON_EvaluateNurbsBasisDerivatives(
int order,
const double* knot,
int der_count,
double* N
