ETO Forms McNeel Example
Just tried the McNeel Python example script attached and it doesn’t seem to run correct when I copy and paste it into the Python editor maybe someone can take a look and see what is wrong, as a nubie to Python I am using the examples as reference as I learn so would like to find out what any issues were with the script. Looking at the code I would expect to see the drop down menu have all the options listed but all I get is “Density” the first option in the list.
All advice welcome.
# SampleEtoCollapsibleDialog.py
# Copyright (c) 2017 Robert McNeel & Associates.
# See License.md in the root of this repository for details.
**import** scriptcontext
**import** rhinoscriptsyntax **as** rs
**import** Rhino.UI
**import** Eto.Drawing **as** drawing
**import** Eto.Forms **as** forms
# Sample dialog class extending the Eto Dialog([T])
**class** **CollapsableEtoDialog** (forms.Dialog[bool]): # return True or False from ShowModal()
**def** **__init__** (self):
self.Title = "My Collapsible Eto Form"
self.Resizable = **False**
self.Padding = drawing. **Padding** (5)
# Custom label helper to set alignment
**def** **L** (text):
m_label = forms. **Label** ()
m_label.Text = text
m_label.VerticalAlignment = forms.VerticalAlignment.Center
m_label.TextAlignment = forms.TextAlignment.Right
return m_label
# set content of the collapsed section
self.collapsePanel = forms. **DynamicLayout** (Visible = **False** , Padding = drawing. **Padding** (40, 10), DefaultSpacing = drawing. **Size** (5, 5))
self.collapsePanel. **BeginVertical** ()
self.collapsePanel. **AddRow** ( **None** , **L** ("Density:"), forms. **NumericUpDown** ())
self.collapsePanel. **AddRow** ( **None** , **L** ("Maximum angle:"), forms. **NumericUpDown** ())
self.collapsePanel. **AddRow** ( **None** , **L** ("Maximum aspect ratio:"), forms. **NumericUpDown** ())
self.collapsePanel. **AddRow** ( **None** , **L** ("Minimum edge length:"), forms. **NumericUpDown** ())
self.collapsePanel. **AddRow** ( **None** , **L** ("Maximum edge length:"), forms. **NumericUpDown** ())
self.collapsePanel. **AddRow** ( **None** , **L** ("Maximum distance, edge to surface:"), forms. **NumericUpDown** ())
self.collapsePanel. **AddRow** ( **None** , **L** ("Minimum initial grid quads:"), forms. **NumericUpDown** ())
self.collapsePanel. **EndVertical** ()
self.collapsePanel. **AddRow** ( **None** , forms. **CheckBox** (Text = "Refine mesh"))
self.collapsePanel. **AddRow** ( **None** , forms. **CheckBox** (Text = "Jagged seams"), forms. **CheckBox** (Text = "Pack textures"), **None** )
self.collapsePanel. **AddRow** ( **None** , forms. **CheckBox** (Text = "Simple planes"))
# button to toggle collapsing
self.collapseButton = forms. **Button** (Text = "v", MinimumSize = drawing.Size.Empty)
self.collapseButton.Click += self.collapseButton_Click
# a few buttons always shown at the bottom
self.previewButton = forms. **Button** (Text = "Preview")
self.cancelButton = forms. **Button** (Text = "Cancel")
self.cancelButton.Click += self.cancelButton_Click;
self.okButton = forms. **Button** (Text = "OK")
self.okButton.Click += self.okButton_Click
# set default buttons when user presses enter or escape anywhere on the form
self.DefaultButton = self.okButton
self.AbortButton = self.cancelButton
toleranceUpDown = forms. **NumericUpDown** ()
# our main layout
layout = forms. **DynamicLayout** (DefaultSpacing = drawing. **Size** (2,2))
layout. **AddSeparateRow** ( **None** , **L** ("Tolerance"), toleranceUpDown, **L** ("millimeters"), self.collapseButton)
layout. **AddCentered** (self.collapsePanel) # we need this auto-sized so we can get its width to adjust form height
layout. **Add** ( **None** ); # expanding space, in case you want the form re-sizable
layout. **AddSeparateRow** ( **None** , self.previewButton, self.cancelButton, self.okButton);
self.Content = layout;
**def** **collapseButton_Click** (self, sender, e):
**if** self.collapsePanel.Visible:
self.ClientSize = drawing. **Size** (self.ClientSize.Width, self.ClientSize.Height - self.collapsePanel.Height)
self.collapsePanel.Visible = **False**
self.collapseButton.Text = "^"
**else** :
self.collapsePanel.Visible = **True**
self.collapseButton.Text = "v"
self.ClientSize = drawing. **Size** ( **max** (self.ClientSize.Width, self.collapsePanel.Width), self.ClientSize.Height + self.collapsePanel.Height)
# except:
# print "Unexpected error:", sys.exc_info()[0]
# pass # so we don't bring down rhino if there's a bug in the script
**def** **cancelButton_Click** (self, sender, e):
self. **Close** ( **False** )
**def** **okButton_Click** (self, sender, e):
self. **Close** ( **True** )
**if** self. **ShowModal** ():
**print** "Do something, user clicked OK"
# Creating a dialog instance and displaying the dialog.
**def** **TestCollapseEtoDialog** ():
dialog = **CollapsableEtoDialog** ()
dialog. **ShowModal** (Rhino.UI.RhinoEtoApp.MainWindow)
# Check to see if this file is being executed as the "main" python
# script instead of being used as a module by some other python script
# This allows us to use the module which ever way we want.
**if** __name__ == "__main__":
Hi RogerD,
With python, one of the most important things is get indentation correct. The script you have posted lack indentation meaning it is impossible to tell where any definition, if and loops start or end.
There is an option for preformatted code when posting and you will need to use that to post the code here.
From,
Chris
Thank you Chris I have a lot to learn so every little bit of information is appreciated.
There has likely been a change in the way the form is rendered. You will need to set Resizable to True.
self.Resizable = True
You can then resize the form initially before you toggle the collapse.
From,
Chris
Anyone knows where the script was pasted from?
The code can be in the Rhino Developer Samples repository on GitHub.
– Dale
