Do you have a more complete example of something that isn’t working that I can test out? We have made no changes to the .NET, Eto, or any UI initialization from 7.24 → 7.26. Perhaps this is a Windows update issue or some other plugin causing it?
Thanks for reply. I was doing bisection on gitlog and realized that after CEFsharp implementation somehow this workflow is broken. Even if I shutdown CEFsharp application, it somehow blocks to open Eto.Forms dialog and freezes Rhino… I am suspicious it is a threading issue. Obviously CEFsharp still working behind the scene, but it is also strange it effects Eto.Forms. Is it normal?
Did you encounter similar issue with CEFsharp or threading?
