Error ID in use Pachyderm
Hi, I have a problem with Pachyderm. I’ve been working with Rhino 8 the whole time. It used to work normally, but after updating Rhino some components disappeared in Grasshopper. I thought reinstalling it would fix the issue, but it actually got worse. Now Pachyderm won’t start at all and shows the error: “Unable to load plugin, ID already in use.” I looked at other forums where people had the same issue with different plugins. I tried following their recommendations, but it didn’t help (the way i understood it, there was supposed to be a duplicate that should be deleted manually, but that wasnt the case, as far as i am able to tell). In the end, I even uninstalled and reinstalled Rhino completely, but nothing changed. It shows itself in Packet manager as installed, but it does not work.
Hi, @Dany_Sviderski. This is very specific to the Pachyderm plugin. Please contact them directly at info@orase.org, if you haven’t already.
