I realized that the Centroid result from the 2nd curve closed planar curve (list of 3 curves) of the list isn’t calculating, however when using the Mesh Area it does calculate such Centroid value. Maybe someone can help me understand the reason for this? Thank youCentroid error.gh (17.2 KB)
Thanks for your suggestion @inno. Regards
Thank you for your time. Just for your knowledge the curves came from a longer definition as a result of a plane intersection with a quite homogeneous and balanced quadmesh.
Best regards
Filipe
