I have a script that has images required for the UI, and I was wondering if it was possible to embed the images in the script, instead of having to save them somewhere on the hard drive. So I googled it, and came across something called base64. I can extract a string of characters from an image, but I can’t figure out where it goes from there.
Does anyone have experience with embedding small images in a Python script (so that there are no dependant files required)?
I’m having some trouble opening my saved image, and I suspect it’s because of the delay in saving the image to the hard drive. There is about a 1/2 second delay. I was wondering if there is a way to save the image to memory instead of an actual save to see if it’s more instantaneous.
What I’m trying to do is attach an image to a script I have, without relying on images saved somewhere on the hard drive. Like this:
It works very well with the images pre-saved, but I’m just trying to push the envelope (my envelope anyway) to see if I can do this without having dependent files. Your example was very helpful in creating the images “on the fly” but I can’t load the images when I select the various radio buttons. I notice that the images take about 1/2 a second to show up in explorer so I’m thinking this delay might be causing the issue. Here is a short video where you can see the delay.
I don’t even know if this is possible, so if you don’t think it is, just let me know and I will abandon this project and stick with the dependent images.
