Elefront error: Cannot create an instance of the interface
Hi. I do try to create some Keys/Values modifications using the Elefront 5 components and I am getting this error: Cannot create an instance of the interface
How I can fix this issue?
Material KEY from Layer VALUE.gh (10.7 KB)
P.S. Elefront 4 was much better than the actual 5 version.
Hi, I believe this is an issue with the script, not eleFront. Your post doesn’t have the 3dm file, so I can’t assess the exact scenario, but if I use the information from one of your other models, it seems to be working fine. The problem is this:
Looks like you are passing a layer into the Modify Rhino Objects component, when I think you want to pass the objects themselves (see the “successful” note).
