Eel: straight, colour-coded wires for the Grasshopper canvas
I’ve released a plugin called Eel, which replaces Grasshopper’s curved wires with straight, orthogonal runs that step around components and can be colored by data type.
The reason I built it: on a definition of a few hundred components, I kept losing track of which wire went where. Grasshopper’s curves all look alike and cross at every angle, so tracing one from an output to its input means following it by eye through everything else. Straight runs at right angles, each in its own lane, are far easier to follow, and color by data type tells you what a wire carries before you click it.
What it does
Orthogonal wires with adjustable corner rounding, switched on and off from a panel
Wires route around components, and are kept apart from each other rather than stacking into one thick line.
Click a wire to edit it: drag a corner, add or remove breaks
Colour by hand from a 15-colour palette, or automatically by data type, with a legend and optional labels on the wires
Isolate one colour and everything else dims, so you can follow a single thread through a definition
Also included: wireless send/receive, a gate component, and sticky notes
Things worth saying up front
Rhino 8, Windows only for now. Mac is on the list.
It’s a paid plugin, $9.99 once, one person on up to two computers. There’s no trial at the moment.
Item, list and tree wires keep their line character, and Grasshopper’s own wire display settings, selection and error colours all behave as before.
Your definitions are untouched. Eel only stores the wire styling you choose, inside the file, and a definition saved with Eel opens normally for anyone who doesn’t have it.
One switch turns it off and gives you Grasshopper’s own wires back.
Install from the Package Manager (search “Eel”) or from the listing: Food4Rhino link
It’s a first release and I’d genuinely like to hear where it falls over, particularly on large or unusual definitions. Bug reports and feature requests both welcome, here or by email.
