Text editing is improved in Rhino 6/ WIP. It is possible to use different fonts, italic fonts oder bold font.
Nevertheless, it is crucial to have the ability to use different font heights within one text block. This would be so helpful. Right now we have to make different text blocks for every font size.
that’s a pity. Would it be so difficult as one can already use different Fonts in V6? IMHO it’s more obvious to use different font sizes than different font types within one textblock.
Nevertheless, thanks for your effort.
PS: Archicad, Revit,… are useing Uniform Rich Text Formatting, resp. it’s Options - which is very good.
The YT item says that Rhino already supports varying font heights. There just isn’t an interface in place yet to allow the user to change this. Since this is about adding new functionality to Rhino, this is not critical for the release of Rhino 6. As the item stands now, the interface will be added in a 6.x release.
I don’t understand why you just activate it. This makes no sense. Why would I use different fonts within a text block (as it is programmed in Rhino WIP)?
Whereas we (everyday) use descriptive text blocks with a bigger header and a smaller sub-description. It’s so laborious to build this up with single text blocks that are stacked on each other.
This is possible in every other CAD software I know.
Pushing this back to the top.
I would agree that it is a real drag not to be able to use multiple text sizes inside a single text box. If I can have multiple fonts I should be able to have multiple sizes too.
