Edit annotation styles in Rhino8 wip
Finally got around to trying 8 wip. When I try to EditAnnotationStyles under the Drafting menu it says Unknown command: _AnnotationStyles
I finally was able to edit my style by going to Tools>options>AnnotationStyles and did some dimensioning. But when I tried to save it, it would not save as a version 7 file even though the dimensioning was very simple
hand-hold.3dm (80.8 KB)
Is this a bug or am I not understanding something. I’ve been using Rhino3d since I started in version 5 and am now at version 7 and use it quite a bit for various types of drawing.
Hi @Joe4,
I’ve logged the menu issue.
https://mcneel.myjetbrains.com/youtrack/issue/RH-74729
Also, I was able to open your file in V8 and save as V7. So we’ll probably need more details.
– Dale
I had first saved the file as V7, then added dimensions, then went to save it again choosing V7 and replacing the already existing file. That’s when it complained that there were things in it that could not be saved as V7. Hope this helps.
Joe
