Easy way to delete text within string and keep numbers
Is there a easy way to delete text part in strings?
One-liner assuming one number in each item:
dbl = double.Parse(string.Concat(str.Where(c => c == '-' || c == '.' || (c >= '0' && c <= '9'))));
str.gh (3.9 KB)
Faster version for multiple numbers:
str_multi.gh (5.2 KB)
private void RunScript(string str, ref object dbl)
    dbl = ExtractDoublesFromString(str).ToArray();
        public static IEnumerable<double> ExtractDoublesFromString(string str)
            var len = str.Length;
            var curpos = 0;
            for (; ; )
                double t = 0;
                curpos = FastStringToDouble(str, ref t, curpos);
                if (curpos != -1)
                    yield return t;
                else
                    yield break;
  public static double FirstDoubleFromString(string str)
    double t = 0;
    FastStringToDouble(str, ref t);
    return t;
  public static int FastStringToDouble(string str, ref double result, int start = 0)
    if (start >= len) return -1;
    for (var i = start; i < len; i++)
      var c = str[i];
      if (c >= '0' && c <= '9')
        var neg = (i == start) ? false : (str[i - 1] == '-');
        var intResult = c - '0';
        var j = i + 1;
        for (; j < len; j++)
          var curchar = str[j];
          if (curchar == '.')
            result = intResult;
            var k = j + 1;
            var scale = 0.1;
            for (; k < len; k++)
              var digitchar = str[k];
              if (digitchar < '0' || digitchar > '9')
                break;
              result += scale * (digitchar - '0');
              scale *= 0.1;
            if (neg)
              result = -result;
            return k;
          else
            if (curchar < '0' || curchar > '9')
              break;
            intResult *= 10;
            intResult += curchar - '0';
        if (neg)
          intResult = -intResult;
        result = intResult;
        return j;
      else if (c == '.' && i < len - 1)
        var nc = str[i + 1];
        if (nc >= '0' && nc <= '9')
          result = (nc - '0');
          var scale = 0.1;
          var j = i + 2;
              break;
            result += (curchar - '0') * scale;
            scale *= 0.1;
          result *= 0.1;
          if (neg)
            result = -result;
          return j;
    return -1;
