@ormallen I am testing out the Easy cut plug in. Very cool, and great work. I although I have a question about holes. In this test model the plug in sees these two outside members as the same even though the second one has holes in it. Thanks in advance for taking a look.
Indeed, the program doesn’t tell holes, it only handles object main dimensions. But there is a way of managing such things: select the object with holes, open object properties tab, navigate to Attribute User Text panel and change the Name value (or add it if it doesn’t exist). Then program will show this object in separate row.
