I wanted to use the same material but change shade / tiling size after duplicating a material and assigning on different objects . However, “remove instancing” is greyed out. I feel like I was able to do this while using Rhino 7.
Any ideas as to why ‘remove instancing’ is greyed out?
@maxsoder do you know when remove instancing is supposed to be enabled, when disabled?
It didn’t have “i” icon even though the material was duplicated. If not instanced, shouldn’t I be able to adjust each material without affecting each other? Every time I make any color adjustment, both materials are affected
What I’m trying to do is, duplicate a material with the same bitmap file, but treat them as completely separate materials so that color/size adjustments can be made without affecting the original material. I’m sure I was able to do this with Rhino 7 after duplicating and removing instance.
Untitled.3dm (1.1 MB)
@jdhill , sorry to drag you in.
Is the problem in the above the same/similar to the issues I was having a few weeks ago with that warning stripe material? I think this turned out to be a Rhino error, and I just gave up trying to duplicate materials, because it seemed to do this type of behavior.
Something like the forward duplication cannot be independently modified, but the backward original could, or vice/versa.
hard to say, as I’m not seeing the behavior reported with the given file – it seems to be working as expected on win11 8.3.24009.15001, the textures do not appear to be affecting each other, and I can make color/size changes to each independently
Many thanks.
I certainly cannot do that. Why would it be working on another computer? That was just a test file I made, but this problem occurs in the all the files.
Version 8 SR3
(8.3.24009.15001, 2024-01-09)
Commercial
here is what I see
Version 8 SR3
Not For Resale Lab
go to the textures panel and un-check this
