Drawing ellipse using Circumference and perimeter
Hi all,
i want to draw an ellipse using its circumference. i have the length of the curve. 42.075 m and i need an ellipse with same perimeter. i searched for different mathematical solutions but i couldn’t find the solution.
actualy my goal is to divide an ellipse into equal 0.425m parts. in order to do that, i firstly calculated the length and now i want this length as the perimeter of ellipse.
any help?
As far as I know, there are an infinite number of ellipses that can have the same perimeter - different aspect ratios. What you can do is create one you like and then scale the result to the length you want…
Fixed length ellipse.gh (7.4 KB)
@Helvetosaur
Wow! thank you. it did the trick perfectly. it was the best approach possible to this problem.
Regards,
Kaveh
