0904
1
Hi All,
def Sel_Ln():
rt, obj_ref2 = RhinoGet.GetOneObject("Sel Ln", False, ObjectType.Curve)
print "sel_rtt"
def Sel_Crv_Cls():
cc, obj_ref1 = RhinoGet.GetOneObject("Sel Crv Cls", False, ObjectType.Curve)
if (cc != Result.Success):
Get_Ln()
else:
Sel_Ln()
Sel_Crv_Cls()
how come once you start the first def Sel_Crv_Cls()
if the result is the same as success, the second def Sel_Ln() starts
is printed “sel_rtt”
but the method: RhinoGet.GetOneObject("Sel Ln", False, ObjectType.Curve)
is not executed?
0904
2
def Sel_Crv_Cls():
cc1, obj_ref1 = RhinoGet.GetOneObject("Sel Crv Cls", False, ObjectType.Curve)
cc2, obj_ref2 = RhinoGet.GetOneObject("Sel Crv Cls", False, ObjectType.Curve)
you cannot request the method twice. . .
. . .with identical signature
dale
(Dale Fugier)
3
Try this:
import Rhino
import scriptcontext as sc
def test():
go = Rhino.Input.Custom.GetObject()
go.SetCommandPrompt("Select first curve")
go.GeometryFilter = Rhino.DocObjects.ObjectType.Curve
go.Get()
if go.CommandResult() != Rhino.Commands.Result.Success:
return go.CommandResult()
curve0 = go.Object(0).Curve()
if not curve0:
return
go.SetCommandPrompt("Select second curve")
go.EnablePreSelect(False, True)
go.DeselectAllBeforePostSelect = False
go.Get()
curve1 = go.Object(0).Curve()
if not curve1:
return
# TODO...
if __name__ == "__main__":
test()
– Dale
