Rhino 8 SR 35 ships AWSSDK.Core.dll (3.3.0.0, msil, .Net Framework v4.5). This dependency seems to have been introduced here due to AWS Marketplace billing: https://mcneel.myjetbrains.com/youtrack/issue/RH-96585
This creates a blocking issue for us at ShapeDiver, especially because .Net Framework v4.5 variant of the DLL is being used. We run most of our Rhino 8 systems on .NET Framework 8 already. The AWS DLLs contain different methods depending on .Net version being used. Example of an exception this causes once our code tries to use the S3 client:
Method 'GetAllObjectKeys' in type 'Amazon.S3.AmazonS3Client' from assembly 'AWSSDK.S3, Version=3.3.0.0, Culture=neutral, PublicKeyToken=885c28607f98e604' does not have an implementation.
This happens because the AWSSDK.S3.dll shipped by us in this case is a net8.0 version, which conflicts with the net45 AWSSDK.Core.dll already loaded by Rhino.
It is very restrictive if McNeel ships AWSSDK.Core.dll as part of Rhino, I expect further issues to pop up due to this in the future, also for others. @fraguada do you see a possibility to remove this dependency again from Rhino?
