Distortion at corners - surface creation between two irregular polygons
Hi Forum,
I am trying to create a facetted flat surface between two irregular polygons, one upper/outer and one lower/inner. Lofting them doesn’t give me a surface I can use. So I am trying use sweep 2 rails in grasshopper. however I am getting distortions at the corners. it seems the inner lower polygon doesn’t have as many kinks or sub sections. thus when you get to sharp corners there is a distortion. what strategy can I use to create a realistic surface between these two polygons. see files attached. in reality they are inclined walls of a pond.
RUSH BED SHAPES.3dm (382.9 KB)
SHAPES OF RUSH BEDS.gh (17.6 KB)
See if this can help.
Though there are several valid ways, starting with what Leopoldo already showed—your question brought a random memory back from this post + a piece of C#:
SHAPES OF RUSH BEDS.gh (12.2 KB)
You can use the control points or tighten alignment with curve divisions:
SHAPES OF RUSH BEDS - RHINO FORUM.gh (41.3 KB)
Sharing final script
