Is there any simple way to identify/select points that are greater than a specified distance from a surface?
Hello- use PointDeviation to identify, a script would be resquired to select - rings a distant bell, I may have something…I’ll check.
That always happens to me, it’s difficult, what I do is block or hide what I’m not using at the moment
You can try this script - select a surface or polysurface and enter a max distance, any selectable points further than that distance from the object will be selected…
SelPtsFurtherThanDist.py (883 Bytes)
if the surface is not to complex:
workaround without script:
build a helper volume:
_offsetSrf (solid=yes)
select everything inside this object
_SelVolumeObject
_lock
_selPt (select all remaining points)
