Display Issue - Curves - Moire effect
BETA (9.0.26272.12304, 29.09.2026)
draw a line parallel to x-axis … my example 100 mm long
arrayLinear 300x with 0.16 distance
depending on the zoom level i get different moire effects.
i would have not complained in the year 2006 on a 1280x1024 pixel screen.
but i wonder in 2026 on a 3,456 × 2,234 retina display. (default display scale)
do i miss some settings like anti aliasing or similar ?
… or is this just a strong geometry effect that even a modern display engine does not have a strategy to overcome ?
effect is not interference with grid: no grid:
different zoom levels:
thanks for having a look - tom
What’s interesting is that in your first image, in the “clean” regions the pixels are alternating 1 light and 1 dark with the dark lines on, say, the even pixels (2, 4, 6…), then there’s a “blurry” region where the darks are lighter and the lights are darker, but on the next “clean” region, the dark lines are still on the even pixels.
I would expect a Moire pattern to have a parity swap between consecutive clean regions with the blurriness coming from the transition between them, but that seems to not be the case here.
What I’m seeing (in Rhino 8 on Windows) is when the effective line width (combination of linetype line width, display mode scaling, and OS-level display scaling) is set to a whole number of pixels, Rhino picks the nearest whole pixel to draw the line. If the effective line width is not a whole number of pixels, Rhino draws full pixels on the bottom of the line with a faded pixel at the top to make up the difference. This will always give a Moire pattern when trying to draw, say, 10 lines per 21 pixels because there will be an extra pixel localized to one gap out of every 10.
A better anti-aliasing might be to have a fractional pixel on both top and bottom so that extra pixels could be spread over multiple lines. There might still be noticeable effects even then though.
Yes, these effects are more severe in Rhino BETA, on both Mac and Win with Direct3d.
I logged RH-99358 Display: alternating line widths
