Hi all,
when right click into rhino window, it happens 2 cases:
- Repeat the previous command
or
- Show context menu (if context menu delay is set to 0)
and 2 above cases cancel my current operation (eg. While drawing polyline, right click will cancel drawing).
How to disable right click event of rhino?
Thanks!
You can’t unilaterally disable the right click.
You can, on a command by command basis, tell Rhino which commands you do not with to repeat in Options - General, in the “Never repeat these commands” list.
You can also turn on the right-click delayed context menu and shorten up the delay so a right click will always bring up the context menu instead.
Options - mouse
