I’m able to get the control points from the dimension object and move it using:
dim = rs.GetObject("Select dimension to reposition", rs.filter.annotation)
if dim:
rs.EnableObjectGrips(dim, True)
newPt = rs.GetPoint("Pick new location)
rs.SelectObjectGrip(dim, 2)
rs.Command("_Move {},{},{} {},{},{}".format(dimPt2.X, dimPt2.Y, dimPt2.Z, newPt.X, newPt.Y, newPt.Z), echo=False)
rs.EnableObjectGrips(dim, False)
but I don’t know where to go from there to distribute a number of dimension evenly?
I want to mention that the dimensions in the first image is done with Elefront, so it’s automated, now I just want to automate how it looks on a page instead of dragging them around manually
Hello- I’d use rs.ObjectGripLoaction(idx,pt) for this - that way you can make an evenly spaced list of points, or a vector to increment points from the lowest one, and set the grip locations accordingly - you just need to figure out the grip index(es)for the ones on each dim that you care about - I think there are only 4 or 5.
grip indices:
rs.ObjectGripLocation(idx,pt) doesn’t seen to work for dimension control points, so I went back to rs.Command("_Move")
this script is not very clean, I’m just starting in Python. But it seens to work for me. There’s the before/after screen shots showing the dimensions are distributed in the X direction.
Thanks for your help!
dims = rs.GetObjects("Select dimensions", rs.filter.annotation)
if dims:
dimPtsX = []
dimPtsY = []
for dim in dims:
rs.EnableObjectGrips(dim)
dimPt = rs.ObjectGripLocation(dim, 2)
dimPtsX.append(dimPt.X)
dimPtsY.append(dimPt.Y)
maxX = max(dimPtsX)
minX = min(dimPtsX)
maxY = max(dimPtsY)
minY = min(dimPtsY)
xDist = maxX - minX
yDist = maxY - minY
xStep = xDist / (len(dims) - 1)
yStep = yDist / (len(dims) - 1)
start = minX
step = xStep
count = len(dims)
xPos = [start + (c * step) for c in range(count)]
yPos = [start + (c * step) for c in range(count)]
for i in range(0, len(dims)):
rs.EnableObjectGrips(dims[i])
rs.SelectObjectGrip(dims[i], 2)
rs.Command("_Move {},{},{} {},{},{}".format(dimPtsX[i], 1000, 0, xPos[i], 1000, 0), echo=False)
rs.EnableObjectGrips(dims[i], False)`Preformatted text
