How would I compare the sizes of two surfaces/polysurfaces with a script?
I want to know which one is bigger before joining them, then assigning the output to the larger of the two input object’s layer… Instead of whatever logic it uses by default.
I find 90% of my joining is adding some little tit like a stair to a huge surface like a floor. Then after joining naturally it decides the whole floor should be changed to the layer I sketched the little addon piece.
Hi Ryan - you can compare areas, or if the difference is clearly pretty large, get bounding boxes and compare the diagonals’ length (points 0 and 6 in a bounding box, assuming you are getting the BB from a RhinoScript or an rs function in Python.
Sub Main()
Dim Id1,Id2
Id1 = Rhino.GetObject("Select a surface or polysurface.", 8+16, True, True)
If IsNull(Id1) Then Exit Sub
Id2 = Rhino.GetObject("Select another surface or polysurface.", 8+16, False)
If IsNull(Id2)Then Exit Sub
Rhino.UnselectAllObjects()
If Rhino.SurfaceArea(Id1)(0) > Rhino.SurfaceArea(Id2)(0) Then
Rhino.SelectObject(Id1)
Else
Rhino.SelectObject(Id2)
End If
Dim BB1, BB2
BB1 = Rhino.BoundingBox(Id1)
BB2 = Rhino.BoundingBox(Id2)
If Rhino.Distance(BB1(0),BB1(6)) > Rhino.Distance(BB2(0), BB2(6)) Then
Rhino.AddLine BB1(0),BB1(6)
Else
Rhino.AddLine BB2(0),BB2(6)
End If
End Sub
