Difference between divide curve and divide length
What is the difference between ‘Divide Curve’ and ’ Divide Length’? They seem to be able to do the same thing that is put points on a curve, what are their operational differences? Can one replace the other?
Thank you for your answers.
Natalie T
Divide Curve always divide your curve into “N” segments with equal length , whereas when you use Divide Length you’ll likely to get end left over which has shorter length than division length.
There are three main curve division options:
 1. Divide Curve
 2. Divide Length
 3. Divide Distance
  1. Divide Curve takes a curve and divides it into a number of equal length segments i.e take this curve and chop it into 10 equal length pieces.
  2. Divide Length takes a curve and divides it into segments of a set length. The last segment will be the remainder i.e if you have a 9m long curve and divide it into 2m segments, the last segment will only be 1m long.
  3. Divide Distance divides a curve so that the points it gives are a set distance from each other. Note that the distance is the euclidean straight line distance between points, not the length of the curve between points.
Curve Division Examples.gh (19.1 KB)
Hope this helps,
Matt
To complete the list, the Dash Pattern component is also a kind of curve division. In case you want a sequence of different length segments (measured along the curve) with optional gaps in between.
