Thanks for sharing this plugin (and the rest of them)
I noticed a glitch when you change the slider with the surface active. The surface redraw interrupt the slider and make the interaction less fluid.
I have also a wish: the ability to increase the degree (or number of CV) when selecting higher curvature.
For example If I have a Deg 2 surface and I want to control the tangent on both sides actually I can’t. Would be nice if this could be allowed.
By default, the surface preview now changes with more fluidity for shaded and zebra display in Rhino 8 and 9. Curvature analysis, draft angle analysis, and EMap are also available in the dialog in Rhino 9.
The dialog now contains a button for increasing the curve or surface degree.
