I’m working on a plugin that writes out a file as it is loaded during Grasshopper initial boot up (via a “PriorityLoad()” method). However, I noticed that on some computers, it writes two files!
After a lot of debugging, I traced this to Hops, specifically the “Launch Local Rhino Compute” option that Hops adds to the “Preferences”
“Solver” menu. It seems like a second copy of Grasshopper launches in the background, which includes loading the plugin and therefore writing a second file.
So my question is… Is there any way to detect whether the current Grasshopper context is being related within a Rhino Compute instance?
I actually solved it, leaving this here for others:
This code
Rhino.Runtime.HostUtils.RunningAsRhinoInside;
Rhino.Runtime.HostUtils.RunningInRhino;
string processName = "";
System.Version processVersion;
Rhino.Runtime.HostUtils.GetCurrentProcessInfo(out processName, out processVersion);
Will result in these values for the “real” Grasshopper load:
"RunningAsRhinoInside": false,
"RunningInRhino": true,
"ProcessName": "Rhino",
"ProcessVersion": "7.18.22124.3001"
But results in this for the “Rhino Compute” Grasshopper load:
"RunningAsRhinoInside": true,
"ProcessName": "compute.geometry",
"ProcessVersion": "1.0.0.0"
