DetailScale "Use detail attribute name" option only works on 1st layout
Strange bug I’ve encountered, not sure if it’s new or I’ve somehow not came across it previously.
It comes down to the little checkbox “Use detail attribute name” in the Text Field dialog:
If I name a detail, then using this option should generate something like this:
TextProperties1
This works on the first layout. On any subsequent layouts with this checked and clicking OK, nothing happens, the dialog closes and no text is added to the text object. Doesn’t matter which formatting I use.
Generating scale based on detail ID works everywhere:
TextProperties2
Now if I manually replace the ID with the correct detail name, it works too and the scale is displayed on the layout. It’s just that the “automatic” way refuses to generate the code.
I’ve tried it in safe mode on this rhino file:
named-detail-scale-text-field-bug.3dm (74.9 KB)
On Page 1, everything works, on Pages 2 to 5 it doesn’t.
Interestingly, if I change the order of layouts, it still works only on the layout that was created first (Page 1 in this case), regardless of its current position.
System Info just in case:
Rhino 8 SR5 2024-3-5 (Rhino 8, 8.5.24065.13001, Git hash:master @ cfc026bc6a854ff160d2b4978aef67a7cbfcb5de)
License type: Commercial, build 2024-03-05
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3080 (NVidia) Memory: 10GB, Driver date: 1-18-2024 (M-D-Y). OpenGL Ver: (null)
- Windows Main Display attached to adapter port 0
- Secondary monitor attached to adapter port 1
OpenGL Settings
Safe mode: On
Graphics level being used: OpenGL (null) (primary GPU’s maximum)
Anti-alias mode: 8x
Mip Map Filtering: Linear
Vendor Name: Unknown
Render version: (null)
Shading Language: (null)
Driver Date: 1-18-2024
Driver Version: 31.0.15.5123
Maximum Texture size: n/a
Z-Buffer depth: n/a
Maximum Viewport size: n/a
Total Video Memory: 10 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.5.24065.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.5.24065.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.5.24065.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.5.24065.13001
Hi Simon -
Thanks → RH-80964 TextField: DetailScale issue
