Design approach to attractor
Hi I am trying to recreate something I really like the look of but feel like I am not thinking to model it in the right approach.
I feel like an attractor point is needed to model it but not entirely sure of the whole process after that, any advise? I will upload the image, thank you
Check this download link below…
https://app.box.com/shared/vb9vvmdlr1duuqaxxf26
Hi Kim,
Thank you for sharing, the script does not seem to be working, do I just need to change all the old categories to the updated commands?
at the moment this is the result I am getting
the only component that needs to be replaced is this one:
anything that creates quads from a grid of points will work:
Ora_ito_Lookalike_Re.gh (429.3 KB)
Thanks for your help!
Another question I had is, is it possible to have a minimum distance between circles while using an attractor point?
could you please attach a picture or something to better explain what you mean? :slight_smile:
How to set a minimum and maximum distance between circles? Don’t want any overlapping
do you have a file with that? :slight_smile:
generally speaking, it looks like you are generating circles centered on a regular grid of points, and the radius of those circles is controlled by attractors of some sort
the distance between two consecutive points measured along X and along Y (which seems the same in your image) is the maximum diameter you want the circles to have in order to avoid overlaps
assuming your attractor will output a value between 0 and 1 for each of your circles, you’ll need to remap those values in the range [minimum_Radius to maximum_Radius], in this case [5 to 25]
