Delete Rhino Objects via GUID
I can’t make it work.
What I want to do is to make a C component that can delete a referenced object via the press of a button.
I have found a code that can replace the referenced geometry with new one from grasshopper. I need to somehow modify it just to delete the original referenced geometry and nothing else.
private void RunScript(List Referenced_geo_to_be_replaced, List New_geo, bool DO_IT)
// Setting inputs to private lists, to make them accessible in the private function
id = Referenced_geo_to_be_replaced;
geo = New_geo;
// Calling an external function
// because otherwise deleting referenced object will expire it AND this c# component while working, during solution, and give an error, illegal stuff…
if(DO_IT){
GrasshopperDocument.ScheduleSolution(5, SolutionCallback);
private List id;
private List geo;
private Rhino.DocObjects.ObjectAttributes attr;
// Deleting old geometry and placing new geometry with duplicated attributes
private void SolutionCallback(GH_Document doc){
int i = 0;
foreach (GeometryBase g in geo){
attr = RhinoDocument.Objects.FindId(id[i]).Attributes.Duplicate();
this.RhinoDocument.Objects.Delete(id[i], false);
this.RhinoDocument.Objects.Add(g, attr);
i++;
return;
delete and replace.gh (3.6 KB)
