Define max. slider value from a component output
Hopefully I’ll be able to describe this clearly. Is there a way to set the max. value of a slider to match the output value of another component.
e.g. Component ‘Whatever’ outputs 40, so the number slider ranges from 0 - 40.
Component ‘Whatever’ updates to output 50, so the number slider ranges from 0 - 50.
I’ve tried several things via domains etc but I can’t seem to make anything sensible.
Many thanks,
Dan
Not with the vanilla GH but the Metahopper plugin should allow you to do this.
Ah interesting - I’ll install it and have a look.
Thanks
slider_metahopper.gh (7.9 KB)
Fantastic - thanks for taking the time
You can always vanilla script things though:
Well, to be exact you are right. Grasshopper is the ultimate tinkering place :slight_smile:
