DataTree is not working
DataTree is not working … which name space I should use. I am making Grasshopper component SDK in C#.
DataTree tree=new DataTree();
which name space I should use?
Hi tsiddikee
You can use DataTree < Point3d > pt = new DataTree < Point3d > ();Create a point3d tree data,Check the attached filedatetree C#.gh (10.8 KB)
Thanks ! I know this bit. I was asking about the name space.
Which namespace should be containing datatree?
I am writing GH Component from Visual studio dot net as Component SDK
Which name space contain datatree, because my code is not recognising
DataTree .
I am using Grasshopper.Kernel.Data
but it is not recognizing DataTree at all
I wrote many GH component in C# dot net from Visual studio, but some how I did not use DataTree before. So, today when I tried to use it, I am bit shocked, it is not recognized, but all other things are recognized and working perfect.
Solved. I just copied all the name space used in GhScripting component :smiley:
And I have added all references … Now it works.
