I have some code below that converts a generic data tree into a 2-dimensional array.
public static T[,] To2DArray(DataTree tree)
T[,] result = new T[tree.Branch(0).Count, tree.BranchCount];
for (int i = 0; i < tree.Branch(0).Count; i++)
for (int j = 0; j < tree.BranchCount; j++)
if (tree.Branch(j).Count != tree.Branch(0).Count) throw new InvalidOperationException("The list cannot contain elements (lists) of different sizes.");
result[i, j] = tree[new GH_Path(j), i];
return result;
This works fine in scripting components. In VS, however, I get
The type arguments for […] cannot be inferred from the usage […]
which makes sense since my input is of type GH_Structure<GH_Vector>.
I am aware one should use GH_Structure<GH_Vector> in VS but can’t seem to get my code above to work with that approach. Would someone mind to help out, please?
You forgot to finish adding your Type T in the method:
public static T[,] To2DArray<T>(DataTree<T> tree)
return result;
Maybe add it as an extension to the DataTree class?
public static Extensions
#region DATA TREE EXTENSIONS
public static T[,] To2DArray<T>(this DataTree<T> tree)
return result;
#endregion
By the way I think personally that its better to think about Data Trees more like Jagged Arrays in .NET they share more of a similar logic in data structure than a [,] array does.
below an example of how you can convert a Jagged Array to a Data Tree:
/// <summary>
/// Convert Jagged Array to a Data Tree
/// </summary>
/// <typeparam name="T"></typeparam>
/// <param name="data">Jagged Array to manipulate </param>
/// <returns> A Grasshopper Data Tree matching the same data structure as the input
/// Jagged Array </returns>
public static DataTree<T> ToDataTree<T>(this T[][] data)
DataTree<T> dataTree = new DataTree<T>();
int totalBranches = data.Length;
for (int i = 0; i < data.Length; i++)
GH_Path path = new GH_Path(i);
for (int j = 0; j < data[i].Length; j++)
dataTree.Add(data[i][j], path);
return dataTree;
