I have many backup files that I saved almost every day for a year. I recorded a lot of data as UserTexts on geometries. I’d like to build a script that could read every file and access UserTexts to see if and when it has been changed.
Is there a way to loop on the rhino files of a windows directory using python and then read UserTexts and store them in a variable?
Did anybody try to do something similar ?
Thanks
Hi B Cohin,
The script below might get you started.
It reads all rhino files in a choosen foldertree and prints the usertext key-value for all objects in the files:
import Rhino
import os
def check_file_usertexts(filepath):
rhinofile = Rhino.FileIO.File3dm.Read(filepath)
objecttable = rhinofile.Objects
for objref in objecttable:
obj_id = objref.Attributes.ObjectId
obj_name = objref.Attributes.Name
keys = objref.Attributes.GetUserStrings()
if len(keys) == 0: continue
print 'object {} named {} in {} :'.format(obj_id,obj_name,filepath)
for key in keys:
print key,' -> ',objref.Attributes.GetUserString(key)
def walk_directory(directory):
for root, directories, filenames in os.walk(directory):
for filename in filenames:
name, extension = os.path.splitext(filename)
if extension == '.3dm':
filepath = os.path.join(root,filename)
if __name__ == '__main__':
directory = rs.BrowseForFolder()
if directory:
Does this help?
-Willem
Hi Willem,
Thank you, this is just what I needed.
I can read a list of Rhino file without opening them and store what is inside into my script. I just need to think of a better algorythm now to process the data.
Thank you
