hi nathan, i could not find much information on this, can you briefly sum up what it is and what it can do? or at least post a link to some more info.
also, from what i have found and from what you write and from what i conclude now, is that going to be available as a standard part of rhino later and just a plugin while wip or how is that going to go?
It exposes Raytraced as a render engine you can set as current renderer to render in the render window, aka offline render, aka modal render, aka production render.
It will be the default renderer in Rhino 7 replacing the old Rhino Render. Itāll then be called Rhino Render.
rhino-render-next is for those who canāt wait until I get around making the change in Rhino WIP v7.
@nathanletwory following on from our earlier discussion about CPU vs GPU, would getting an eGPU for my MacBook Pro speed up rendering performance at all? Iām not clear if Cycles uses both CPU and GPU or just CPU?
The theory is yes, BUT I have to say upfront that I donāt know how well it actually works, as I havenāt had yet the chance to test such a configuration. On the Mac the GPU(s) for such a configuration then have to be AMD GPUs, at least a GCN 2nd card, but probably GCN 4th or GCN 5th makes more sense (see this handy page for info on cards and architectures. I can say this much: the one Mac machine we have with a recent AMD GPU works fine using the GPU for Raytraced, I think @jeff also was able to use the AMD GPU on his Mac for testing.
In theory it is also possible to get both CPU and GPU render at the same time, but the Intel OpenCL support has been a bit spotty sofar, so I havenāt provided any easy interface how to set that up (if you ask really nicely I could still write about that here on the forums thoughā¦)
That should be not a problem at all. I have here a scene with three predator heads that give a total of 2.9M tris.
Looking at one of your earlier screens I see trees with foliage. If those are all separate mesh objects with relatively few vertices/faces per object that may be a problem. Perhaps you could share the file with me privately using Rhino - Upload to Support so that I could have a look and make some good suggestions on how to speed up the rendering (especially the startup) ?
Now that Iāve got it so that turning on Raytrace doesnāt take an age, Iām just trying to export a render using view capture to file.
I have the settings such that it can only use 2 of the 4 cores of my machine due to the problems I was having before.
It is, however, taking an age to export even a low res image. It is about 1000x650 (I think) and it has been going for 10+ mins and only 60% complete. Set to 500 cycles. Seems very slow still.
Also, thanks for the info on GPU. If I get some of these issues ironed out, I may get an eGPU. Been looking at either an RX580/590 or Vega 56.
Would rather not spend ~Ā£500 on something that doesnāt work though so if @Jeff or others can provide some more info on what has / is working for them that would be great.
Having got an image out of it, it seems like Cycles ignores some settings of materials. As you will probably see in the file, I have set the brick texture and the ground texture to have their opacity significantly reduced such that the material is more subtle. This works fine with the standard rhino renderer but not in Raytrace. See comparison images below.
EDIT: also, 7 minutes after the file stopped exporting, Rhino is still beach balling. It seems that prior to doing the view capture to file, the viewport completed its āpreviewā raytrace render. I then waited for the export to finish and then following completing the export, it has decided to render the viewport again from scratch.
I donāt have the textures you used in your file. If you can use Save As and ensure textures are included (there is an option for that on the file dialog), then re-upload please.
Anyway, Iām seeing lots of performance problems with your file in Rendered, Artistic, Technical (no real lockup, but still several seconds - much better than 20-30 seconds for the other modes) - plain lockups when trying to select anything.
Iām investigating, poked @jeff about it as well.
Remember to press the Pause button at the bottom of the viewport (or use the TogglePausedActiveRealtimeViewport command), or just use a very low number of samples.
Thanks, yes I did forget to do that. However, youād also hope that if it was absolutely necessary that Rhino might do it automatically when initiating a view capture to file. Certainly, redoing a render that has just been done twice (once low res, once not quite so low res) it does seem a bit unnecessary to have to then render it a third time.
That indeed shouldnāt happen. I personally donāt like the capture dialog anyway, so I generally just use the command-line version _-ViewCaptureToFile.
@robinp, investigating the file @wim found that removing the 48 point lights made Rendered mode (and raytraced) work much more smoothly. I have created a YT item for this as well, but it is hidden since your file is attached for investigation.
If you need a higher resolution, just use the āScaleā setting in the command line⦠it maintains the viewportās aspect ratio, so itās probably the easiest way to get larger output.
Also note: It doesnāt matter which display mode youāre in (as long as itās not Wireframeā¦otherwise all youāll get are wire depths) ⦠So working in Shaded mode with the ZBuffer ON might be easier to wield.
@robinp Something I like to do for a nice effect is to capture the scene using Arctic mode, then run ShowZBuffer to turn on the depth buffer view, and capture it again⦠Take the two output results and multiply them together using your favorite image processor. Iām working on something for V7 where this can be done entirely in Rhinoā¦
This is really awesome. Thank you! I had know idea about the showZbuffer command. Really cool and when outputting with a Raytrace image via viewcapturetofile it would be perfect. Also a good workaround for the problem Iāve had as described here: Rhino render depth channel export failure
