Hello friends
How can I clear that part of the rectangle section that is in the cylinders?
sandboxtopology.gha (59 KB)
cover-v2.gh (127.5 KB)
hi @martinsiegrist
yes
Not sure about the radius so I just used a value bigger than the intersection at the nodes to illustrate the situation.
You can run a Solid Difference with the B input flattened. Not the most efficient solution but it gets the job done.
cover-v2.gh (133.4 KB)
Thank @martinsiegrist
I do not know why component 79 and 82 turn red.
cover-v2.gh (460.2 KB)
What’s your goal when you’re projecting the closed brep onto the plane?
BTW you can create the planes much easier… with an Evaluate Surface component…
cover-v2.gh (447.3 KB)
