My .net plugin used to read/write a lot of Custom Object User Data when it was compiled for Rhino5, and it worked really fine.
I’m currently migrating to Rhino6, and I’ve got an issue with these custom user data. During a session they are written and read just fine, but if I Save/close the doc and reopen, every data is lost.
Do you have any pointers on what has change between V5 and V6 for custom Object User Data?
Thanks for helping @nathanletwory , I don’t really know how but I got it to work.
I rewrote my custom class, I think there was an issue with the read() override command. (Still, it was working in V5)
Hi, unfortunately I’m not certain of the reason behind these bugs.
I had a try/catch to return Nothing when reading custom data when a particular element was missing, and since migration to v6 it was always returning nothing. My best guess is loss of data when my test file was converted to V6 format.
I’ve removed this unsafe system and now I make use of ContainsKey() instead, with a fallback value for each variable:
If dict.ContainsKey("test") Then
_test = TryCast(dict("test"), String)
Else
_test = ""
End If
