Curves not extruding properly
I am trying to extrude some a line with some curves. However, when I do that, the curves just turn into line segments which I can’t use.
How can I get the curves to extrude normally?
Thanks
Hi William - the extrusion is fine, the render mesh is not so good - you can try setting DocumentProperties > Mesh settings to something finer.
https://wiki.mcneel.com/rhino/meshfaq
You can also try running DivideAlongCreases > SplitAtTangents=Yes on the objdect, that might clean it up.
