Although the UI’s _Rebuild can output a periodic curve with total number of control points equal to double the curve degree, RC’s Curve.Rebuild outputs a minimum of 2*degree+1. I’ve tried various arguments but haven’t found a way for Curve.Rebuild to mimic _Rebuild at this extreme.
Start curve: Degree(3) PtCt(6) IsValid(True)
Rebuilt curve: Degree(3) PtCtIn(3) PtCtOut(7) IsValid(True)
Rebuilt curve: Degree(3) PtCtIn(4) PtCtOut(7) IsValid(True)
Rebuilt curve: Degree(3) PtCtIn(5) PtCtOut(8) IsValid(True)
from __future__ import print_function
import Rhino.Geometry as rg
def main():
degree = 3
pline = rg.Polyline.CreateInscribedPolygon(
circle=rg.Circle(10.0), sideCount=degree)
ncA = rg.NurbsCurve.Create(periodic=True, degree=degree, points=list(pline)[:-1])
print(
"Start curve:",
"Degree({})".format(ncA.Degree),
"PtCt({})".format(ncA.Points.Count),
"IsValid({})".format(ncA.IsValid),
for pointCount in range(degree,degree+3):
ncB = ncA.Rebuild(pointCount=pointCount, degree=degree, preserveTangents=False)
print(
"Rebuilt curve:",
"Degree({})".format(ncB.Degree),
"PtCtIn({})".format(pointCount),
"PtCtOut({})".format(ncB.Points.Count),
"IsValid({})".format(ncB.IsValid),
if __name__ == '__main__': main()
