Hi all, I am having an issue with poor curve boolean command outputs. Usually this is caused by the file tolerance being too large but I copied it into a file with very small tolerances but am having the same issue. Any ideas?
CB test.3dm (16.8 MB)
Hi James -
I see you are running Rhino 7.
This is what I get in the current version of Rhino 8:
Yes, I need to run this on Rhino 7 as that is what I have.
Hi James -
I’m afraid you’ll have some manual construction to do then.
