Hello Dale,
I am referring https://developer.rhino3d.com/guides/opennurbs/getting-object-attributes/
to fetch the layer information, but when I am using onxModel->m_settings.CurrentLayerIndex() API to get the current layer index it returns some garbage value.
Note: I have two layers added in the model, “Default” & “Layer01”. Layer01 is my current layer
Please advise.
Thanks & Regards,
Sandip Ichake
dale
(Dale Fugier)
2
Hi @sandip.ichake,
Can you provide a sample 3dm file and source code, that I can run here, that isn’t working for you?
Thanks,
– Dale
Hello Dale,
Please find the below code snippet, which I’m using to read the layer objects. Also I have attached, sample model created.
Line_L_Layer01_M_Plastic_L_Dots.3dm (30.4 KB)
ONX_ModelComponentIterator it(m_onxModel, ON_ModelComponent::Type::ModelGeometry);
const ON_ModelComponent* model_component = nullptr;
int iLayer = 0;
for (model_component = it.FirstComponent(); nullptr != model_component; model_component = it.NextComponent())
const ON_ModelGeometryComponent* model_geometry = ON_ModelGeometryComponent::Cast(model_component);
if (nullptr != model_geometry)
const ON_3dmObjectAttributes* attributes = model_geometry->Attributes(nullptr);
if (nullptr != attributes)
const ON_Layer* layerP = nullptr;
const ON_ModelComponentReference& model_component_ref = m_onxModel->LayerFromAttributes(*attributes);
if (!model_component_ref.IsEmpty())
layerP = ON_Layer::Cast(model_component_ref.ModelComponent());
int iCurrentLayer = m_onxModel->m_settings.CurrentLayerIndex();
Is there any settings/prerequisite that needs to set before querying the CurrentLayerIndex() method?
I have also observed that, API’s with V5 names are showing similar garbage values, please find the below image for the same:
dale
(Dale Fugier)
4
Hi @sandip.ichake,
Does this help?
static int ReadCurrentLayer(const wchar_t* filename)
int current_layer_index = -1;
if (nullptr == filename || 0 == filename[0])
return current_layer_index;
ONX_Model model;
bool rc = model.Read(filename);
if (!rc)
ON_UUID current_layer_id = model.m_settings.CurrentLayerId();
ON_ModelComponentReference model_component_ref = model.ComponentFromId(ON_ModelComponent::Type::Layer, current_layer_id);
const ON_Layer* layer = ON_Layer::Cast(model_component_ref.ModelComponent());
if (nullptr != layer)
current_layer_index = layer->Index();
– Dale
Thank you Dale! This is helpful.
I have few questions:
- Is there any way to identify default layer? or How to know ON_Layer is default or not?
- Is default layer index(0) fixed?
- Is there any different mechanism to read default layer? or the code which I have mentioned above is sufficient to read default layer.
Thanks & Regards,
Sandip
dale
(Dale Fugier)
6
Hi @sandip.ichake,
The code I posted above demonstrates how to obtain the current, or default, layer from a 3dm file.
– Dale
