I have divided some curves by length, and from each of the interval, I made a perpendicular line. now I want to take only the lines (the perpendiculars) which have intersections with the curves I mentioned. I already tried but I could not find the solution
I new in grasshopper too, And Ihave bad english. I think you should use boolean operators, which will check the curves for intersection. and then use somthing like this
Thank you, by the way, your English is good
the powerful of google translate)))))!!!
Thank you so much, can you tell me why you used shift path?
You are welcome. I have used it to get same number of branches as number of lines.
In that manner Dispatch pattern has been matched.
Thank you for your help, I should spend more time on understanding data tree
