CrvDeviation gives a clearly wrong result for the two polycurves in the attached file. DeviationProblem1.3dm (46.3 KB) It reports the maximum distance between the polycurves as 5 when in fact the largest deviation is .0000000004. While the error is obvious in this example it does not inspire confidence in the reliability of CrvDeviation results. Rhino V5 has the same problem. (Polycuve B is the border of a tapered extrusion created using Polycurve A.)
