CrossGems is a professional jewelry software that allows you to design any complex model easily and quickly without having technical CAD knowledge.
Our goal is to take advantage of parametric design without the need to learn traditional parametric trees, creating a powerful modeler that can be used by anyone.
CORE AND FEATURES
All objects are linked in real time to automatically adapt when edited, allowing you to delete or modify Boolean operations or any of the 100+ CrossGems tools and keeping the parametric history in all cases. Additionally, this feature applies to Rhino gumballs, allowing you to reset transformations (move, scale, and rotate) applied to model parts and restore deleted document objects at any time, including SubD objects and Meshes, while maintaining compatibility with Rhino’s Record History function.
It can also be used as a traditional modeler without the parametric system, adding the modeled objects as normal Rhino geometry.
For the most advanced users, all the tools in Rhino are also available in Grasshopper, making it one of the most versatile software in the Rhino world.
INTERFACE
CrossGems can be run with its own interface, simplifying the workflow and as a Rhino plugin while keeping all the parametric features for users used to Rhino UI. The Command History Panel, available in Rhino and CrossGems UI, is the visible part of this system that allows the user to interact with and manage all the model’s components.
RENDERING
It also includes a rendering material library with over 300 materials and grounds for the integrated physics-based render Cycles.
Materials and grounds are assigned with a single click, displaying the object weights in real-time while using any tool or simply selecting objects in the document. Furthermore, CrossGems will automatically swap materials when changing display modes to achieve the best quality for every situation.
COMPATIBILITY
CrossGems is capable of importing and converting gems from other software, such as RhinoGold and Matrix, as well as importing Panther files while maintaining 100% parametric history.
ABOUT CrossBytes 3D
Our background goes back to the origins of RhinoGold, developing from RhinoGold 3 to RhinoGold 6.5 for more than ten years. Finally, the company was acquired by a multinational. At this point, we created Panther 3D, the world’s first parametric jewelry software from Rhino and Grasshopper. CrossGems is its evolution in every respect.
Throughout all these years we have learned thanks to listening to users and we can say that we have built a program with jewelers and for jewelers within reach of anyone, and we intend to continue doing so. So if you have any requests, doubts, or suggestions, feel free to email us at hello@crossbytes3d.com and let us know.
Complete details and to download…
Posted Nov 15, 2022 by Carlos Perez on Rhino News, etc.
