Hi everyone,
I’m working on a project where I need to create a diamond mesh using 0.25 cm x 0.25 cm pipes that adapt to a specific surface. Here are the steps I’ve followed so far:
- Used the
Squish
command to flatten the surface. - Created the diamond mesh lines on the flattened surface.
- Generated a Grasshopper file to turn those lines into pipes using the
Pipe
command.
However, I’m encountering some issues and would like to simplify the process by doing everything directly in Grasshopper. Could anyone guide me on how to achieve this or suggest a better approach?
Thanks in advance for your help!
Diamond mesh…3dm (1.3 MB)
Tubos.gh (6.6 KB)
