I tried creating a planar Brep, without the hole, and a resulting brep is Valid.
However, when I add the hole crv, the rg.Brep.CreateTrimmedPlane method creates invalid Brep.
I would be very grateful for any kind of help on this issue.
This is the the example:
# a) create outer and inner (hole) rectangles
vecUp = rg.Vector3d(0,0,1)
pln1 = rg.Plane(rg.Point3d(0,0,0), vecUp)
pln2 = rg.Plane(rg.Point3d(600,400,0), vecUp)
outer_rect = rg.Rectangle3d(pln1, rg.Interval(0,2000), rg.Interval(0,1200))
hole_rect = rg.Rectangle3d(pln2, rg.Interval(0,800), rg.Interval(0,400))
outer_rect_crv = outer_rect.ToNurbsCurve()
hole_rect_crv = hole_rect.ToNurbsCurve()
#outer_inner_crv_L = [outer_rect_crv] # WORKS! Creates a valid Brep
outer_inner_crv_L = [outer_rect_crv, hole_rect_crv] # does not work. Creates invalid Brep.
# b) create a brep from rectangles
brep = rg.Brep.CreateTrimmedPlane(pln1, outer_inner_crv_L)
print 'brep: ', brep.IsValid
I’m no expert on this by any means, but the documentation states that the curves given should form one closed curve. But they don’t, because they are two curves.
But you helped me by providing the link to the Brep.CreateTrimmedPlane method, which made me realize that it accepts only outer curves, and not inner ones.
Thank you for your effort, and willingness to always help!
