I am trying to create a new Dimension Style from scratch and set it as the current one in Grasshopper.
I tried to build the code but something is wrong since the new style is created but not set as the current one. I t should be something easy but I am not able to solve the problem. I just compared the index of new and old styles and they are different.
private void RunScript(ref object New_Style, ref object Current_Style)
var style_name = "IMT-Style";
Rhino.DocObjects.DimensionStyle dimStyle = new Rhino.DocObjects.DimensionStyle(){
Name = style_name,
Id = Guid.NewGuid(),
DimensionScale = 0.15,
LengthResolution = 0,
ArrowLength = 2.5,
TextGap = 1,
TextHeight = 3,
FixedExtensionOn = true,
FixedExtensionLength = 5
// Add the newly created text style to the document
Rhino.RhinoDoc.ActiveDoc.DimStyles.Add(dimStyle, false);
// Set the newly created text style as the current style
Rhino.RhinoDoc.ActiveDoc.DimStyles.SetCurrent(dimStyle.Index, false);
New_Style = dimStyle.Index;
Current_Style = this.RhinoDocument.DimStyles.CurrentIndex;
Additionally, each time I run GH new Dimension styles are created: IMT-Style-01, IMT-Style-02, IMT-Style-03…
Is it possible to adapt the code so in case of having stored the same name do nothing? Would you mind taking a look at that @AndersDeleuran@magicteddy ?
I think you need to search the style again after it’s inserted in Rhino.
By the way, I noticed if the Annotation Styles window is opened and the component is launched, it doesn’t refresh the table. Insertion works but you have to restart the window to see it.
private void RunScript(string x, ref object New_Style, ref object Current_Style)
//find it again
Rhino.DocObjects.DimensionStyle ds = Rhino.RhinoDoc.ActiveDoc.DimStyles.FindName(style_name);
if (ds == null)
Name = style_name,
ArrowLength = 2.5,
TextGap = 1,
TextHeight = 3,
//find it again
Rhino.RhinoDoc.ActiveDoc.DimStyles.SetCurrent(ds.Index, false);
New_Style = ds.Index;
Sorry to bother you again. I’ve just added the arrowType1 and arrowType2 but I think nothing happens
I think It may be caused since I have more components in the same grasshopper and everything runs at the same time so the Dim Style is not uploaded.
Can the Redaw method solve this situation? Is there any way of changing the priorities in order to run this component first?
private void RunScript(string Name)
var style_name = Name;
//Find if the dimension style exists
if (ds == null)
Name = style_name,
ArrowLength = 2.5,
ArrowType1 = Rhino.DocObjects.DimensionStyle.ArrowType.Arrow,
ArrowType2 = Rhino.DocObjects.DimensionStyle.ArrowType.Arrow,
TextGap = 1,
TextHeight = 3,
//find it again
var New_Style = ds.Index;
var Current_Style = this.RhinoDocument.DimStyles.CurrentIndex;
Indeed, you have a problem of the order the components are computed. And the arrows do work as intended.
You should add an output to your C# component that returns the Dimension Style, and use that as an input to your Python component, so it triggers in the correct order.
Anyway, I am capable of getting and output with the dimension style name for the c# component but I am not able to modify the python component and make it works since I do not know how to change the code in a right way. I would appreciate any help on this
