Create arched brick patterns in grasshopper
I would like to create arched brick patterns, with adjustable brick width, length and height, also horizontal and vertical mortar width, as shown in the photo below.
Right now in my model, I can only make brick patterns running on a straight line which is not desirable as shown in the screenshot below, attached is the grasshopper script I used to make this.
Brick patterns.gh (36.4 KB)
When I try to find a script that allows bricks to run along the curve of the arch, I have found this script from the old forum which allows me to control an arch and divided points on the arch, yet I don’t know how to combine the brick pattern with it. I’m also not sure if this is the best way to achieve my desire outcome too.
9_BricksOnArc.gh (9.9 KB)
I would really like to create brick patterns that curve along the arch like the one in the photo. Please help… :persevere: Thank you so much in advance! :blush: :pray:
Hello, i just saw your question. i propose to show you how to create this patern on picture, if you’re ok, so maybe it can help you. tell me if you’re interrested.
I’m interested!
Hi Chris, I’m interested in how you made these arches. Is it possible to send me the script? It would really help me.
king regards,
Roelof
Hi! Did you figure this out?
Check this
arched_brick.gh (23.2 KB)
Hey, I tried your code on Rhino 8, but sadly it’s not working. It asks for some Python plugins which aren’t available on Food4Rhino anymore. The project shows the arc line but not the bricks around it. Is there any solution to make it work in the modern version using only Grasshopper? Because it looks very awesome!
arched_brick_update.gh (10.9 KB)
for anyone that needs it
