Create a mesh between two gyroid meshes
I made a mesh between two gyroid mesh with grasshopper like this.
However, the details don’t seem to be working.
Roughness here is a factor in not being able to proceed to the next step. If you have any advice, I would appreciate it.
Check this thread
Cheers,
BVR
Is that the same geometry as this:
If so I can post the GH file I used to make it - and a couple of other similar ones.
Thankyou for your reply! The one I want to make is a little different because it’s a model with variable thickness, but I’d like to reference it if you don’t mind.
I typically don’t use meshes for my designs, but I’m OK to try tweaking one that does to facilitate making a 3D print of it. That’s what happened with this one back in Feb 2023.
I found a version of the basic GH file on this forum, but the result wasn’t 3D printable because it had no thickness, and it used as its basis a couple of oddly shaped meshes that also could not be printed. So I spent some time rearranging and adding GH components to allow a choice among the original’s 3 different base shapes, and to allow specifying the size of the final result and also it’s thickness.
minimal_surfaces.gh (41.8 KB)
The grasshopper was really similler to mine, so it was easy to understand. Thank you so much!
Hi, thank you for introducing me to this thread! I made a new unit cell by using grasshopper in this thread, and it looks so nice!
