Contour Data Structure seems not correct. I have to renumber path then match tree, to keep the structure right. Will this be fixed?
BTW, it’s GH 1.0.0007
Hi!
Read this Help Us Help You
Then, try to attach your .gh with internalized data (and avoid plugins components if there are some).
You can try to disable multithreading, by doing right click here:
and see if that changes something…
tree.gh (28.4 KB)
Yep, it’s a bug
Flattening all the inputs works fine, then Match Tree restores the original:
tree_2021_Aug6a.gh (13.9 KB)
Actually, Match Tree works without flattening.
