Does someone has a suggestion how to make sure that surfaces create by EdgeSrf node have consistent edge sorting, now the indices seem random. Input lines ares sorting correctly and match.
I am looking for a way not as quick fix, using sort the edges along a curve, but to make the surface that is create have consistent ordering of indices/edge (i.e. top edge is always the top edge), as i will reference these at multiple places later in my script
Not sure but it seams that Edge Surface component is reordering the edges itself so it reaches the most efficient way . As said , if we want to do it manually , we should take other paths , like Network Srf , Sum Srf etc.
even curve network is not consistent, and rhino is doing some behind the scene optimization/sorting of edges. Tested with 4 x 1000 pre-sorted curves, with a variety of vertical and horizontal curved curves in same branches, but still the edge typology is not consisitent. For now only sorting by edge length check and/or in combination of relative position to center seems to be reliable. But that’s overhead and less elegant. So still open for any hints.
