Connect points with line
I have highlighted how i want the lines to connect (in blue) from the points, the second image shows how they are connecting when i add a line component and is not how i want them to connect.
Is anyone able to help me with this? Thankyou
Hi @nathanghanakas,
Since a file has not been uploaded, the best advice I can give is flatten and use closest point to map them assuming they are joined to the closes intersection.
we’ve not enough info to help you with this problem. I would indeed start with flatten the output and try to find out what the order of intersection is. play with ‘list item’, ‘dispatch’, etc.
